Air Conditioner Question
Hello everyone. I'm not an engineer and this is probably a stupid question to you guys but I have $20 riding on it.
My buddy is insisting that a standard window air conditioner produces more hot air than cold, is this true?
RE: Air Conditioner Question
More hot comes out the back than cold comes out the front. But that does not necessarilly mean that there is more hot air than cold air.
If we neglect inefficiencies in the system, then the heat lost by the room air in an A/C unit will equal the heat gained by the outside air. You could have more, less, or equal amounts of hot air and cold air. If you have less hot air than cold air, then the hot air will have a larger increase in its temperature than the decrease in the cold air's temperature.
This is not that difficult a subject, but I'm foundering a bit here. It's hard to put this into non-engineer-ese. Post back if you're not satisfied with this explanation.
Doug
Otherwise Bud, being a wise guy, probably would not have made the bet, because if you neglect inefficiencies as djack says... heat is just moved from inside the room to outside of the room and .... nobody would win the bet.
Going the Big Inch!
http://virtualpipeline.spaces.msn.com
Cold air is produced when the air conditioner removes heat from it. This heat must then be rejected to the outdoors, which is why half of the unit hangs outside. It is a one-to-one enthalpy relationship; however, it takes mechanical energy to transfer this heat. This energy creates more heat which is also rejected to the outdoors.
Think of a dehumidifier. It is basically a window air conditioner that throws the rejected heat back into the room. it also throws the mechanical heat into the room which is why a dehumidifier ultimately adds a net heat gain to the room.
Tell your buddy he owes me half of his winnings!
Another friend of mine (he is a neuroscientist so what does he know, right?) told me an a/c is like and refrigerator with an extra fan. He then explained that common sense dictates that if your fridge does not make your house hotter then it makes your food cold then an a/c expels more cold than hot air.
Anyway, thanks for losing my $20 :p
This is actually how my buddy explained it.
the EER is basically the lay man version of te physical unit of effiiciency, which is essentially a ratio of the energy put out divided by the energy used. It's not so much an issue of the heat generated--its how efficient the AC is in turning the energy you put in (in, electricity) to energy out (cold air)
Efficiency is uaully a number from 0 to 1 (obviously, noting is 100% effiicient, some energy is lost. The EER takes taht decimal and makes it a rating, I think so an effiiciency of 0.5 (which means only half the energy is gets put out) is a rating of 5. So rating of 8-10 would mean 80%-100% efficiency (though I am pretty sure that no AC gets a 10, 9.9 maybe or 9.99999).
The total heat produced (not just passed through, i.e. hot air expelled from within to out) is generated by the engine. This heat is directly 3.41 BTU's of heat per watt used by the engine. So...a 10000 Btu air conditioner would need to have close to a 2932 watt engine to be taking a loss on a standard AC (which has an EER of about 16 these days, I am now finding). And this is assuming a high rate of efficiency.
Most air conditioners are under 100 watts. Which means, that in an inefficient air conditioner (100 watts and 10,000 BTUs), it is still generating a net of 9971 (appr) BTUs of cold. I'd say at a ratio of 341-1, that shitty air conditioner is definitely still generating far more cold than hot. There is still some lost due to unprocessed heat energy being leaked by the system, but that is generally little to none.
At this time another friend told me of a time when they forgot to stick the tube on one of those portable a/c's out the window and the room heated up quite a bit. I relayed that, to which he responded:
Alrighty, portable air conditioning units with the hose are not the same as older portable units, or window mounted/giant compressor-type air conditioners. The hose ones use a reservoir of water is used to cool and humidify the air through evaporation. Not sure on the details, but in the end it seperates the warm water (humidity) out of the air and kicks it out the hose, and then releases the cooler less humid air back into the room. Should you leave the hose in the room you get no heat removed, but a little more added from the machine.
Bigger types (like window units) are refrigerators, except smaller and with one added fan. This one sucks air out of the room, cycles it through the parts that need cooling, and then kicks it out the back at a hotter temperature. The temperature increase is not, however, significant enough to counteract the amount of cooling given.
Going the Big Inch!
I remember once I saw ice loaded into the top of the Amtrak cars. It looked like a ton, but I think it melted in less than 24 hours. They were loading it again in the afternoon.
But, that was in Texas.
Going the Big Inch!
This has nothing to do with efficiency. It is the Second Law of Thermodynamics. Heat cannot be moved from a cold thing to a hot thing without expending energy to do it. The theoretical amount of energy needed is defined by the temperature difference.
There are so many "efficiencies" with air conditioning that without defining exactly which one you are talking about the term is meaningless.
Put an air conditioner inside your room room. Close all the doors and windows. Turn it on. The room's temperature will start rising.
Why? Because the electrical cord is bringing power in, the a/c is doing work, generating heat.
So I guess your friend wins the bet. The a/c will creat more heat.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Going the Big Inch!
Albert Einstein
Going the Big Inch!
COP of 3 means three units of heat transfered for one unit of power in.
First Law of Thermodynamics....the best you can do is break even
Second Law of Thermodynamics....you can't break even
