Welding acc. to AD 2000M
What is minimum distance between shell circumferential weld and attached stiffening ring weld.
Is this value = 50 mm min.?
RE: Welding acc. to AD 2000M
You'll have to check AD2000
There are certainly minimum distances between welds but I can't remember what they are.
