Slope for steam line
My senior comments that I should make slope for steam line. I checked previous design in the existing plant and found that no slope. There are only steam trap and low point drain (from drip leg). Is this a good design practice to make slope? In my opinion, it is not standardized to weld the inclined pipe shoes for setting the line at the same elevation. Please comment.
RE: Slope for steam line
jproj
Spirax Sarco's literature has some good info. The more basic book is "Steam Utilization", and the one I carry around with me is "Hook-Ups".
If you want some graphic reports of what can happen with improperly drained steam lines, check out www.kirsner.org . There are several published reports on accidents due to water hammer with large steam systems. These usually happen at low pressures, on start-up.
I also talked to a couple of other engineers who have worked in many plants and they do not recall that this is a typical installation/construction detail in their experience either. I talked to one of our senior piping designers who said he has seen it in a couple of plants as a customer requirement but the majority he has worked in do not require steam lines to be sloped to low points. It could be that they weren't aware of it yet all were aware of ensuring flare lines are properly sloped yet no one recalls steam lines being sloped as a routine design practice.
Condensate removal from steam lines in my experience is addressed by installation of drip legs at various locations, either where the steam header rises up or at every xx ft down main headers where xx is set usually by a company's engineering specifications.
Do the plant operators and maintenance people a favour by helping condensate drain from steam lines by sloping them to the drip legs. Really.
The truth is that sloping steam piping is the correct way to do things. However, in actual application this may not happen. The best way to make sure that you don't have a water hammer event is to drip trap your mains. I have read a rule of thumb for drips is one every 200' for piping sloping in the direction of flow and 100' for piping sloping against flow. A drip at a riser will take the place of one of these drips. I put a trap every 100' just to cover myself.
This is a case of engineers knowing the correct way something should be done and the field doesn't believe that it is important. Cover yourself. It might cost a little more, but unless you get a contractor you can work with, you need to make sure your design is a good one.
TBP suggested a slope of 1" in 20 feet. The main piperack along the back side of our crude and FCCU cracking unit is close to 3000 feet. I can attest that one end isn't over 12' higher than the other end.
I have seen a recommended slope from as little as 0.25" in 100' to (listed here) 1" in 20'. Given that your senior (as well as nearly everyone here) is telling you to slope the steam line, I would recommend that you listen. They have the experience. If you want to know how much to slope the line, ask your senior. If you disagree, confront your senior with your concerns! Let your senior share their knowledge and enlighten you (there's no substitute for communication!).
jproj
1) The steam system in it's totality is overlooked as an area which needs proper attention and preventive maintenance.
2) Steam leaks are in most cases repaired when production targets are in danger
3) Plants are loosing 30% or more of their steam production in leaks if they do not have a pro-active maintenance program which focusses op steam trap inspection and repairing.
4) In a small petrochemical or chemical plant with medium pressure steam and steam tracing on product lines you can encounter easily more then 500 steam traps. Are they regularly checked and inspected? The answer is no.
5)Companies are throwing money into their boilers and are not even aware of it.
6)These facts show that people do not know what they are dealing with. The construction guy in general do not know the sh.. he leaves behind when there is no slope. I will try to get a number from the books, but I would point to a very interesting article called"Steam Trap Performance Assessment" from The US Department of Energy
http://www.pnl.gov/fta/15_steamtrap/15_steamtrap.htm
Steven van Els
SAvanEls@cq-link.sr
And don't even get me started on piping code issues. It is nothing short of amazing that there aren't more fatal accidents.
1. Good pratice says slope and trap to the excess, if you have ever seen An 8" elbow separate because of water hammer start-up you will understand.
2. Because you specifed slope dosen't mean your contractor installed it that way.
3. Provide for easy warm-up on start-up is also a key. Large bore piping with quick opening valves lead to trouble. Provide a small by-pass to allow steam to heat up the piping befor full flow.
Steven van Els
SAvanEls@cq-link.sr
Your latest reply reminds me to ask another question about expansion loop. I always find the expansion loop of steam line in horizontal. However, you said steam headers should have expansion loop on different elevations. Please comment.
north --> up --> east --> north --> west --> down -->north
Steven van Els
SAvanEls@cq-link.sr
I have found some very very interesting articles on this topic at http://www.kirsner.org/pages/articlesAlt.html in PDF format.
These articles are about accidents with steam, condensate removal, and the mechanisms involved.
If you read the following articles: Condensation Induced Waterhammer, and What Caused the Steam Accident that Killed Jack Smith? , you will understand why steam lines must have a slope among other things.
Steven van Els
SAvanEls@cq-link.sr
damage due to the water hammer - sure if condensate is present and startup procedure is not done right. slope is not the answer. this is easy to find out. climb a cage ladder and check out the main steam header on the pipe rack. what do you observed? its very crooked most especially near the limit stop and the loops. no point checking out the slope there. check out the pipe shoe and notice that a lot are lifted. again no point checking out the slope.
In answer to the slope question, standard engineering specs call for 1/4" slope in 10' for steam flow in direction of pipe pitch. Traps are recommended to be from 300 (newer) to 500'(older) apart in mains if there are no other rises in the line. Traps on mains have safety factors of around 20 in pipe that is perfectly insulated. Assuming pipe is only 80% insulated (as SARCO does in their tables) smallest traps are still way oversized for load so no need to put traps closer than 300'.
Good design dictates that principal distribution mains incorporate a slope of no less than 1:240 (or thereabouts)in the direction of flow.
Clearly this must be complimented with adequately sized drain stubs and trap sets if effective condensate removal is to be achieved.
First time we started introducing steam in this line.......
Once but never again I would like to see this happening.
This 30" line started to have a life of it's own, moving 1 - 2 meters at each hammer blow!!
So please don't tell that there isn't a need for sloping and traps!
Ben
What guidelines are used for counter-current steam/condensate flow?
This is a very interesting topic to me. The steam/condensate flow being discussed is two-phase flow (fluid/vapor), mostly vapor, with very little fluid (the intended condition during operation).
The guidelines Mr. Kirsner stated are typical for our designs, and the greater slope recommended by AJN can't hurt if installation costs aren't significantly hurt.
The guidelines seem appropriate to me, provided: the steam quality is high, piping is well insulated, piping is well maintained, system is thoughtfully operated, and if steam velocities are not too high. To the extent these parameters are not controlled or controllable, the design decisions for the line size, slope, and dripleg spacing may need to change. For two-phase flow, as the proportion of fluid increases for a given relatively high velocity, or as the vapor velocity increases for a relatively high proportion of fluid depth, the flow changes from stratified smooth, to stratified wavy, and then slug flow. If that happens the result will probably be water hammer, and in the case of stagnant sub-cooled condensate the result can be condensate-induced water hammer.
These are great responses, and I'm inspired to chime in with my experience on steam trap maintenance. Several posters have noted that losing steam to leaks, etc..., only becomes a recognized problem when production capacity starts feeling the effect. I agree!
Many years ago, I made my living by carrying a hand-held infrared temperature sensor around plants and pointing out to the maintenance staff which traps were blowing thru. In my sampling of over 10,000 steam traps of all types, more than 20 percent of them were allowing live steam through to the condensate system, and thus to the air. I visited plants that looked like they had a hundred chimneys spewing steam into the air when seen from afar, and when all traps were repaired or replaced you could actually see the tops of the buildings and distillation columns!
My advice along these lines -- check the traps regularly.
Good luck with your project!
Old Dave
Your post was most helpful as it answers a question I asked in the Power Generating Facility Engineering forum. I wanted to know what codes, guidelines, or standards are referred to for power plant design. I see that BS 806 has been superceeded by BS EN 13480 - 2002, and is now in 5 sections.
Would it be possible that I could receive a copy of the page that describes the requirements you gave in your post? From either the older or current BSI standard would be helpful. Does the BSI standard also discuss velocity limitations for steam piping?
I have the BS806 copy and can fax you the page if you send me a fax no with all the area codes county codes etc. I will be faxing from JHB in RSA. The code stipulates that the slope is to be maintained in all operating conditions, cold, hot, cold to hot etc. That may mean using a 2-3 in 100 slope. The NWS 1451(ESkom Power Generation) spec that we use is more stringent i.e. 2/100 with flow as a minimum.
I much appreciate the offer. I am interested in this information for my own personal growth, I can't afford to purchase the entire standard, neither have I found a lending source via interlibrary loan nor at our national engineering library. No doubt some corp. libraries in the US have it, but I haven't found good avenues to those sources.
My fax is 09-1-513-241-3659 from JHB to USA. Or if you prefer I can be reached by email at knislyna@fosdickandhilmer.com in which case a pdf file would be well received.
I would appreciate the page(s) which specifies/discusses pipe slope. If an adjacent page discusses the related issues of drip leg spacing and steam velocity that would be helpful too.
Would you say what the NWS abbreviation represents? I can find no reference to the meaning of "NWS 1451"?
Best regards,
Ken N-N
