How to map Fluid Pressure data at Node into Pressure B.C ?
Hi.
I completed CFD analysis in fluent s/w, and exported Temperature, Pressure data to i-deas UNV format.
I want to use Temperature, Pressure data as B.C and finished Temperature import by "From Results..." function. But, as to the pressure import, there's no direct method in i-deas.
Any ideas will be very grateful.
Thanks.
Thanks.
