Vapor Pressure
Vapor Pressure
Vapor Pressure
All:
How to determine vapor pressure using HYSYS? Also it is always true whether Critical pressure is always greater than vapor pressure.
sp77
RE: Vapor Pressure
I don't use Hysim, so can't say how Hysim calculates vapor pressure of a substance at a given temperature.
The quick answer is YES, Critical Pressure is almost always higher than Vapor Pressure... almost always, because at the Critical Point, Vapor Pressure = Critical Pressure!
Practically speaking, Vapor pressures only exist between the Tripple Point and the Critical Point.  The define the transition point between the liquid and gas phases for any temperature between the tripple point and critical point.  Above the Critical Temperature, distinguishig between the liquid and gas is difficult, so vapor pressures (per say) cease to exist.
For a detailed discussion of how it applies to the state of water, see
http://www.lsbu.ac.uk/water/phase.html
http://virtualpipeline.spaces.msn.com
RE: Vapor Pressure
In petroleum engineering the cricondenbar (not the critical point) is the maximum pressure at which liquid and vapor can coexist.
RE: Vapor Pressure
Nice point 25362!   Now we're talking.  I did say "practically speaking", thinking that (esp. from my perspective) it is only on limited occassions where it is necessary to distinguish in detail exactly when and how a phase change occurs.  In I've never had to distinguish between the bubble point and the dew point, especially as they approach the critical point, as long as the product was delivered on one side of it or another.  When operating I prefer to stay well to one side or the other of the phase change too.  That approach is usually sufficient for pipeline work since, in pipelines if a critical point exists its usually not going to exist for a very long time, or failing that for a very long length but, I can see where it may make a difference in complex process works.
RE: Vapor Pressure
The last (July) issue of Hydrocarbon Processing has an article titled Understanding LNG rapid phase transitions that may interest sp77.
RE: Vapor Pressure
SP77
1) Create the stream with the composition required
2) set the vapour fraction to 0 and the temperature to the desired temperature where you want to know the VP. Then HYSYS will calculate the pressure=the VP (or more precisely the bouble point pressure=the vapout pressure) at the specified temperature - similar if you want to calculate the dew point set the vapour fraction to 1
Since by the nature of your question i guess that you are very unfamiliar with the use of HYSYS and perhaps also thermodynamics? i must warn you that your result will depend on many parameters e.g. selection of EOS, components in your mixture, definition of pseudocomponents (if any) and so on!
Is the e.g. about pure water then use a table (not HYSYS)!
If im correct in my assuption then i must encourage you to seek professional assistance either in-house or by a consultant if these results shall be used for anything important (IMHO).
Best regards
Morten
RE: Vapor Pressure
(1) For a pure component, the critical pressure always exceeds the vapor pressure at any other temperature.
(2) For a multicomponent mixture, the vapor pressure at the dew point temperature may exceed the "true" critical pressure.  As noted by 25362, the cricondenbar is the point at which the saturation pressure is highest.  The best way to see this is by making a "phase envelop" calculation.  This is basically a P-T curve showing the entire locus of the equilibrium curve - saturated liquid and saturated vapor all the way to the critical point.
(3) For multicomponent systems, the thermodynamic option (equation of state) chosen can have a huge impact on the resulting calculation and one must use a great deal of experience and insight to make the proper choice.  Therefore, I heartily endorse Morten's cautionary notes.
RE: Vapor Pressure
One more word of caution - if you just set the vapour fraction to 0 (or 1), and the temperature specified is outside the phase envelope, HYSYS will give an unpredictable result - or nothing at all. In that case, a phase envelope will quickly show you what is going on.
Cheers,
Joerd
RE: Vapor Pressure
All:
Thanks for all the comments.........
sp77
RE: Vapor Pressure
Just to follow up on joerd's post. Yes, be very careful about setting the vapour fraction to 0 (or 1). By doing so, you effectively set the process stream to be at its bubble (or dew point).
PhD - Permanent Head Damage
RE: Vapor Pressure
Radionise
As i also said - but the bubblepoint will be equal to the vapour pressure (as long is the fluid is not critical as joerd pointed out)!
The man _wants_ to calculate the vapour pressure.
Best
RE: Vapor Pressure
                 soapbox
Agreed.
         It does seem
                  to be hard to
                         remember the original
                                question around here.
   Going the Big Inch! worm
RE: Vapor Pressure
how does a pig system design?
RE: Vapor Pressure
abiodun1
usually we dont critisize language problems (I know about these since english is not my morther tounge) but your little typo had me lauging smile
Best regards
Morten
RE: Vapor Pressure
thanks morten,
i noticed the statement you are pointing at.
