European motor connections
I am looking for wiring diagrams for european electric motors. In my job we rewire and refit european machinery using the 220v, 380v, 415v, 50/60hz motors existing on the machines.
RE: European motor connections
To make this clear; Wiring diagram, i guess you're referring to Terminal markings or Lead markings as STArdelta pointed out. My best guess is that you're looking for "wiring connection diagram".
Well, european machines (IEC) are mark with U1, V1, W1 and U2, V2, W2 for six leads out terminals which is equivalent to T1, T2, T3, T4, T5, and T6 for NEMA machines.
If you intend to rewire to be tap for specified voltage, just follow the wiring connection diagram on the nameplate.
Try to check if your machine has its nameplate. I bet it has!
Gunnar Englund
www.gke.org
