CATIA V4 Plot Sheet??
Currently our process requires us to create individual plot sheets for each draft. For example our design may contain 10 sheets (drafts) which translates to 10 plot sheets. My question is. Is there a way to batch print all 10 plot sheets??
RE: CATIA V4 Plot Sheet??
Most V4 companies write (or buy) a batch plotting routine that does what you want. If you're in the Detroit area, I'm sure a VAR like INCAT or RAND or Dassault can probably help you out.
