omron plc to remote area with fibre optic transmission
hi thank you for the feed back I am getting.
Well I would like to use omron plc and at the same time I do have some (100) input/output 200 m far from the site i wonna use remote device but at the same time I have to use fibre optic transmission so if some has an idea about these.
thanks
thanks
RE: omron plc to remote area with fibre optic transmission
Most PLC manufacturers also allow the use ethernet to communicate with remote I/O, so conversion to/from fiber optic is easy, if ethernet will work for your application.
I think Profibus is even an option with Omron.
You should contact an Omron sales person for help in selecting the correct hardware.
