Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Congratulations on a brilliant idea and a great site..."
Geography
sloth4z (Mechanical)
14 Jul 06 14:34
I made multibodied part with a shaft going through the center of a plate (two intersecting solid bodies).  I would like to cut the union out of the shaft leaving two shafts (one on each side) and a plate.  If I use the Combine->subtract option, then the plate disapears.  Is there a way to subtract the union from the shaft, but leave the plate?  I am using SW2006 SP4.1.
I know of several workarounds for this example, but none that would work with more complicated parts.
Helpful Member!(2)  rfus (Mechanical)
14 Jul 06 15:13
Use Indent with the cut box checked. You can even put a tolerance in.
RFUS
rfus (Mechanical)
14 Jul 06 15:16
After reading again I think you may want to use combine with ADD and then use the SPLIT feature
rfus (Mechanical)
14 Jul 06 15:26
Freakin Friday.
I meant use Split with the face of your shaft and then do a delete body. So many ways to skin cats.
I'm going home.
Helpful Member!  CorBlimeyLimey (Mechanical)
14 Jul 06 15:28
Split is the way to go. You will have to play with the options/selections to be left with the portions you want.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
14 Jul 06 17:44
Thanks guys.
Here is the process I used.
1. I started with two solid bodies (shaft and plate).
2. Insert->Features->Split
3. I selected both faces of the PLATE, and then clicked on "Cut Part"
4. I selected "Consume Parts" and checked the middle shaft piece.
That worked like a charm.  This also works for my more complicated problem as well.  I love this forum.
Close Box
Join Eng-Tips® Today!
Join Us             Close
