Codes, Standards and Recommended Practices
Friends,
Pls differentiate Codes; Standards; Recommended Practice etc. I have read it somewhere but not remember whether on the same forum (search did not return any good results).
thanks
thanks
RE: Codes, Standards and Recommended Practices
Standards - We do things this way so life is easy. eg. ANSI pressure ratings. Also, companies may have their own standards, to make sure work is similar.
Recommended Practices - I suggest you do it this way because it has worked for me in the past. eg. ASME RP's. You don't have to do it this way, it is just recommended.
I am sure there are other definitions, and other ways people use these words.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
http:/
Glad I am consistent with ASME.
Albert Einstein
