API issue with manual prompt to save children
Hello again,
I am in the process of running a macro that I created to open up all the files in a directory, dig around, add some custom properties etc.  It works great.  Largely due to the help I received from numerous individuals on this forum.
The issue I am having is that about 5% of the files, upon saving and closing will require manual input to continue the operation.  SW will essentially prompt me to save some child component of the assembly it was performing the operation on.
Is there a command I can add to the code to always "say yes" to the prompt of "do you want save..."  Or is there some other way to get around the problem.
Thanks for everyone's help,
-Shaggy
RE: API issue with manual prompt to save children
Check out ModelDoc2::Save3 in the API help.  You want to add the save option swSaveAsOptions_SaveReferenced.  Since this is a bitmask enum you can simply add it to the "Options" argument of the Save3 function, like (to quote/modify the syntax of the help file):
CODE
retval = ModelDoc2.Save3(Options + swSaveAsOptions_SaveReferenced, &Errors, &Warnings )
Handleman,
Thanks for the reply.
I have added the option to save referenced as well as tinkered with the option of avoid rebuild.  Unfortunately, neither of these had the effect I was hoping for.  I am still being prompted to save the occasional part.
Is there a way that I can do an if statement that essentially says:  If we receive a prompt, then click yes?
-Shaggy
You could try PTFB.  It's a separate utility that "Push[es] The Freakin' Button" for you.  I haven't used it myself, but I've heard of it.  It's a general Windows utility, not SW specific.
