Converting entities error
Has anyone seen this before?
I created a new sketch and converted entities from another. When I extrude-cut, I get the error that there are open geometries. OK, easy fix.
But, when I fix, each line one at a time after each fix, gets another line copied on top of it! uuuuugh!![[banghead] banghead](https://www.tipmaster.com/images/banghead.gif)
![[hairpull3] hairpull3](https://www.tipmaster.com/images/hairpull3.gif)
I delete the line, redraw it. Then does it again with another line!
Must be a bug. I have never had this problem before.
Have you guys come across this? If so, is there a bug or a fix?
Thanks.
Thanks.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
RE: Converting entities error
I closed SW and reopened finally, out of frustration and eventually got it to work. I also deleted the offending sketch first.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I fix it by redrawing the lines.
If I see it again I will post for you.
I have to go to a mtg for a few hours.
Thanks.
Chris
AutoCAD 06
What I do is go around the sketch and delete each line. Sometimes there's two, sometimes three, sometimes only one line (seems random). Pick each line and delete it until the final one disappears. Undo (Cntrl Z), so the last line reappears. Go completely around the sketch, then the feature works. This ensures you only have 1 line for each segment, and doesn't recreate the problem like deleting and redrawing the lines does.
Just a normal day with SolidQuirks.
I have found out that if I go to the original sketch where the converted entities came from, then change the line to construction lines, the convert entities sketch gets more lines added.
I think it's a bug. I'm going to send it in.
Thanks ongybill.
Chris
AutoCAD 06
Happens alot when you import data from DXF/DWG.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Chris
AutoCAD 06
