Plug Valve for Low Temperature
Hi All:
I am looking for a plug valve for low temperature service. The process liquid is ammonia. The temperature is -28°F (-33 °C). The valve is a 2", 1500#, full port and butt weld connection. If you know of any manufacturers, please let me know. Thank you.
RE: Plug Valve for Low Temperature
http:
No offense meant.
If you do not normally purchase valves for your company, might I suggest you talk to the person (probably someone in I&C) who normally does.
There are many valve manufacturers out there, and most are good. But that is not the point. Chances are, your plant already has a type of low temp plug valve that they "standardise" on, or have in place a SOC (supplier of choice) where they get discounts. The valve you describe is nothing extraordinary. It should be easily obtainable.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
