Catia V5 Fillet problem
I am trying to Fillet a 1 inch diameter piece with a shaft attached to it with a diameter of .875... the fillet needs to be .125, and i can't seem to get it to cooperate.... both these pieces are solids and are being filleted in the degenerative surfaces workbench
TIA
TIA
RE: Catia V5 Fillet problem
If you already have solids, and it's a very straight forward fillet, just do it in Part Design. You should be able to fillet it there with no problems. If you do have problems, make sure both solids in the same body.
Bob
