Determining Weld Size From FEA VonMises Plot
Dear All,
I have been asked to develop weld sizes from a Von Mises plot of a rectangular tank c/w stiffeners. The model was created in SOLIDWORKS/COSMOSM and as such I understand this created a solid brick element model from the parametric model.
I read a NAFEMS report based on a FEMNET project relating to the use of plate models and having to extract particular node stresses and use these to determine minimum fillet weld throat size. I understood the issue here being the relationship between the weld toe stress being remote from the reported connecting node stress.
For a brick element model is it possible to use the Von Mises stress plot values at the various connection details by dividing the stress by the smallest member thickness to give a through thickness stress. From here I would suppose I could use an effective weld throat size based on the weld rod material and work out intermittent weld size requirements.
I hope this makes sense as the proposed method appears to be too simple which makes me somewhat sceptical.
Thanks in advance.
Thanks in advance.
RE: Determining Weld Size From FEA VonMises Plot
