Positive ground.
Positive ground.
Got a positive ground on an instrumented rail car. The car was designed to do coupling based tension measurements, (think how many tons of pull are there between 7 locomotives and the 125 coal hoppers behind).
The car has racks and racks of ancient electrical measurement stuff in it. Looks like those panels in front of the phone operators of old.
Besides all this instrumentation there are house lights, dual 3-71 diesel generators, blowers, battery charger, air conditioning and some controls.
Well like I say, the dang car is wired with a positive ground!!
All the instrumentation is going to be yanked and the car is going to be converted into an escort car for things like Space Shuttle Booster motor sections.
Questions:
1) Why would someone have made this car positive ground?
2) What would be stumbling blocks to converting it to negative ground?
Questions:
Keith Cress
RE: Positive ground.
The entire DC system, thus earthed, will be negative with reference to earth, thus repels water (moisture) and helps prevent corrosion.
What are your reasons for changing the system to negative ground?
Ford used positive ground with six volt batteries. They changed to negative ground about the same time as they went to twelve volt batteries, sometime in the fifties.
How old is the rail car?
respectfully
Can you provide more information as to how either of your points actually work?
Yo waross!
Not sure 40-50s?
Keith Cress
Gunnar Englund
www.gke.org
This is a system that had a single 1,800 pound 30V FLA battery. We have just pulled the dead battery and replaced it with five 6volt batteries. In the midst of this we discovered the positive ground.
The reason we'd like to change it is because all the myriad things that go into making a comfy, high end, "motor home" are generally built assuming negative cases, a car stereo for example.
I suspect that if we don't change it we'll have to worry about:
Stereos.
Laptops.
Every technician who approaches it.
High end communications equipment.
If we do change it we'll have to worry about:
Fans turning the wrong way.
AC Generator controls?
Battery charger.
Engine starters?
A/C controls?
Keith Cress
Keith Cress
I'd say you would have less chance for problems if you kept the dc positive ground. If anyone wants stereo or laptops when riding the instrument car, make them bring their own battery operated ones.
It may not be that hard to change. Fans that old will probably have wound fields and will not reverse direction with a change in polarity. The starter motors should also accept either polarity of current. It is only small equioment such as riding tractors and smaller outboard motors which have permanent magnet fields in the starters.
If you have old brush type battery charging generators, they can be polarized to generate either polarity.
I saw the battery installed backwards in an old genset one time. When the engine was started, the output of the generator built up in the wrong polarity. When the output of the generator reached the point that the cutout relay closed, the 12 volts coming from the battery met the 12 volts going from the generator. The battery overcame the generator and there was an instantaneous surge of current. This re-polarized the generator in the opposite direction and everything worked fine, except that the ammeter indicated discharge when it was charging and vice versa.
We changed it back the same way.
I don't however, recommend this method of polarizing. If the wiring does not withstand the surge, or if the battery cannot overcome the generator there will be interesting issues. The point is: the polarity of DC generator is easily reversed. The exact procedure varies with the type and connection of the voltage regulator, and the internal connection of the generator field.
respectfully
I am not much conversant with the electrical systems in automobiles / rail cars.
While the positive grounded system suffers less with corrosion related problems, I am yet to see any benefit with the negative grounding in DC systems.
http://en.wikipedia.org/wiki/Dynamometer_car
Dynometer cars were state of the electrical art in the 20s and 30s.
That car may be worth something a museum piece, check before you tear it up.
That IS what the car is. I'll pass this to the owner he'll get a kick out of it.
Thanks.
Keith Cress
I would call the California RR museum. The owner might make a swap for pullman car or something closer to what you want.
Keith Cress
I was curious enough to write the California RR museum, his is the answer I got. Im anot trying to mettle jus wanted to see how rare dynamometer cars were.
''Well, I'd hate to see one torn apart. at the very least, I'd like to
see the equipment saved. What company owned the car, and where is it
now?
Kyle
Kyle K. Wyatt
Curator of History & Technology
California State Railroad Museum
111 "I" Street
Sacramento, CA 95814
Phone: (916) 324-7660"
Never discount trading to a museum or donating untill you talk to your accountants. All is not as it may seem.
I shall pass this on.
(a star for the extra effort)
Thanks!
Keith Cress
The reason being that leakage current to ground tends to plate delicate wiring with all sorts of mysterious ionic growths, instead of eating away precious copper wiring. Back in the days before semiconductor electronics, when much insulation was paper and wood, cotton covered wire, and other pre space age materials, humidity, condensation, and creeping moisture was a real problem.
Negative grounding probably started around the turn of the century, when valves required positive supply potentials. But large dc distribution systems still preferred positive grounding wherever possible, especially with buried cables.
These days electronic circuits (mostly) run off a positive main supply rail, so most dc distribution systems are now negative ground, and it would be very impractical to do it the other way.
Keith Cress
Mitsubishi PLC systems are available in Japan and Europe, but in Europe, they are negative ground...
Some systems are not earthed, and have capacitive coupling from both + and - to ground.
Try working on a plant that has all three systems...
Keith Cress
Tiz outta my hands now.
Keith Cress
Hopefully someone will trade the guy a car like the one in the "Wild. Wild West" movie. That on I belive had a pool table in it, playing pool in a moving train has to be different.
I don't suffer from insanity. I enjoy it...
Keith Cress
