Autodesk Map 5, 'Undo' command question
Hi all,
I just started working with Map 5 (~2002LT). The 'undo'-command seems to be affecting also for the 'zoom'-command, unlike in the previous versions. Is it possible to modify the command (this feature really slows things down).
Yours, Heikki
RE: Autodesk Map 5, 'Undo' command question
The Undo commands also undoes Zooms in AutoCAD LT 2000i. You can always undo a number of commands at one go by selecting the down arrow between the undo and redo icons.
I have not had any problems with performance other then application size, could you explain your problem a little better.
