B705 B31.3 Allowable Stresses
i am searching for basic allowable stresses for the following material which is not listed in B31.3:
SB-705 N06625 60Ni - 22Cr - 9Mo - 3.5Cb Wld. Pipe Annealed
in the -20 to 1000 degF range
many thanks.
RE: B705 B31.3 Allowable Stresses
B-705 N06625 is listed in Table A-1 of ASME B31.3.
SB is ASME spec (same material) listed under the Boiler Pressure Vessel Code.
For B31.3 piping you can use the allowable stresses of the B-705 material in B31.3.
