Show or cut a projected curve
I am trying to show a projected curve on a drawing or cut a projected curve on the model, which will of course show on the drawing. I have a model for a rotational mold and I am trying to show areas for sand blasting. I made a sketch and projected it onto surfaces (more than one surface). I could either show the projected curve on the drawing or make a shallow cut into the model, which will show on the drawing. I had first tried to make a shallow cut from a surface to show the areas, but the sketch covers more than than one surface. Any suggestions?
RE: Show or cut a projected curve
Insert, Curve, Split Line.....
... or, create a zero thickness surface using the projected sketch entities.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
