Need SQL Certified Releif Valve
I am looking for an SQL certified relief valve to replace a small 1/4" NPT Kunkle Model 548 we normally use.
Can anyone point  me in the right direction for a small SQL certified relief valve?
VittoZ
Vic.Zanchetta@dehydration.spx.com
RE: Need SQL Certified Releif Valve
Okay, you got me.
What is a SQL certified relief valve?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
SQL is China's pressure vessel certification, similar to the AMSE coded vessels in the US. We have ASME certified relief valves, they have SQL certified relief valves. SQL is in the process of changing it's name to SELO.
Ok. Thanks.
Albert Einstein
