GetTessTriangles Macro
I would like to retrieve the tesselation associated with SolidWorks rendering. How do I do this, and preferably output the data in a nice readable format such as a textfile or excel.
Thanks in advance. (Below is my first attempt)
Option Explicit
Sub main()
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swSelMgr As SldWorks.SelectionMgr
Dim swPart As SldWorks.PartDoc
Dim swEnt As SldWorks.Entity
Dim swFace2 As SldWorks.Face2
Dim vTessTriangles As Variant
Dim vBodies As Variant
Dim swBody As SldWorks.Body2
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swPart = swModel
Set swSelMgr = swModel.SelectionManager
vBodies = swPart.GetBodies2(swSolidBody, False)
'Set swSelData = swSelMgr.CreateSelectData
Set swBody = vBodies(0)
'Set swFace2 = swSelMgr.GetSelectedObject5(1)
Set swFace2 = swBody.GetFirstFace
swModel.ClearSelection2 True
Dim i As Long
i = 1
Do While Not swFace2 Is Nothing
vTessTriangles = swFace2.getTessTriangles(False)
Debug.Print "(" + _
Str(vTessTriangles(9 * i + 0)) + "," + _
Str(vTessTriangles(9 * i + 1)) + "," + _
Str(vTessTriangles(9 * i + 2)) + ")"
Debug.Print "(" + _
Str(vTessTriangles(9 * i + 3)) + "," + _
Str(vTessTriangles(9 * i + 4)) + "," + _
Str(vTessTriangles(9 * i + 5)) + ")"
Debug.Print "(" + _
Str(vTessTriangles(9 * i + 6)) + "," + _
Str(vTessTriangles(9 * i + 7)) + "," + _
Str(vTessTriangles(9 * i + 8)) + ")"
Set swFace2 = swFace2.GetNextFace
i = i + 1
Loop
End Sub
Option Explicit
Sub main()
Dim i As Long
i = 1
Debug.Print "(" + _
Debug.Print "(" + _
Debug.Print "(" + _
i = i + 1
Loop
End Sub
RE: GetTessTriangles Macro
' Go to "Tools --> References" and look for something like "Microsoft Excel xx.xx Object Library".
' Set All SolidWorks References as well!
Option Explicit
Sub main()
Dim exApp As Excel.Application
Dim sheet As Excel.Worksheet
Set exApp = New Excel.Application
If Not exApp Is Nothing Then
exApp.Visible = True
exApp.Workbooks.Add
Set sheet = exApp.ActiveSheet
If Not sheet Is Nothing Then
sheet.Cells(1, 2).Value = "X1"
sheet.Cells(1, 3).Value = "Y1"
sheet.Cells(1, 4).Value = "Z1"
sheet.Cells(1, 5).Value = "X2"
sheet.Cells(1, 6).Value = "Y2"
sheet.Cells(1, 7).Value = "Z2"
sheet.Cells(1, 8).Value = "X3"
sheet.Cells(1, 9).Value = "Y3"
sheet.Cells(1, 10).Value = "Z3"
End If
End If
End If
'swModel.ClearSelection2 True
Dim i As Long
Dim row As Long
row = 2
'i = 1
'Alternatively,
'vTessTriangles = swFace2.getTessTriangles(False)
For i = LBound(vTessTriangles) To UBound(vTessTriangles) / (1 * 9) - 1
sheet.Cells(row, 2).Value = (vTessTriangles(9 * i + 0))
sheet.Cells(row, 3).Value = (vTessTriangles(9 * i + 1))
sheet.Cells(row, 4).Value = (vTessTriangles(9 * i + 2))
sheet.Cells(row, 5).Value = (vTessTriangles(9 * i + 3))
sheet.Cells(row, 6).Value = (vTessTriangles(9 * i + 4))
sheet.Cells(row, 7).Value = (vTessTriangles(9 * i + 5))
sheet.Cells(row, 8).Value = (vTessTriangles(9 * i + 6))
sheet.Cells(row, 9).Value = (vTessTriangles(9 * i + 7))
sheet.Cells(row, 10).Value = (vTessTriangles(9 * i + 8))
row = row + 1
exApp.Columns.AutoFit
Next i
Loop
End Sub
