Deleting Layers
Deleting Layers
I'm having problems deleting layers that AutoCad tells me still contains objects. I am unable to find any objects in those layers and when I have AutoCad Select all it finds nothing to select. What could be causing the problem of Autocad thinking there is still something on the layer.
Thanks.
Thanks.
RE: Deleting Layers
RE: Deleting Layers
RE: Deleting Layers
there are a lot of reasons, why layers can't be deleted.
1. Which AC-version are you running?
2. Do you have a really empty *.dwg? Try ctrl+a.
3. Try ajack's and taffcad's tip, don't forget the blocks inside the dims.
4. Maybe you have empty mtexts, or polylines with the length =0 -> try "_qselect"
My tip: Use "laydel" from the Expresstools, or copy&paste the objects into a new *.dwg...
Hth, Lothar
ADT 2004
ACAD 2002
RE: Deleting Layers
RE: Deleting Layers
RE: Deleting Layers
Thanks again!
