Bus Bar sizing information
Hi All,
I need to know where I can find/buy information on the sizing of bus bar to confirm with IEC60439 for switchgear and equivalent BS & VDE standards.
I need to know about bus bar supports, support distance and the effects in the current carrying of bus bar when they are bent in right angle offset etc.
I do not know if there is any good books out there on panel switchgear design which would help.
thanks all,
thanks all,
RE: Bus Bar sizing information
I have a copy... found it on the web... you should be able to find it through a search...
TULUM
