Is there an easier way to change dangling dimensions
When I have a model and a 2D drawing of the model, and the drawing is dimensioned,I sometimes get dangling dimensions on the 2D drawing if i make revisions to the 3D model.
Sometimes these dangling dimensions are still good but I dont want them printed in dangling colors, so I i have been deleting the dangling dimensiion and re-dimensioning it. Is there an easier way to do this - ie. to confirm that the dimension is ok?
RE: Is there an easier way to change dangling dimensions
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I can drag the endpoint of the extension line but that doesnt change the dangling color
Were these dimensions manually placed?
Do you know why they have become "dangling"? (removed or edited feature?)
I cannot drag the connection points away other than to make the extension lines longer or shorter.
If i have dangling annotations or datum symbols, can replace them by moving them, but I cannot do the same with these dimensions.
An example would be a dimension between two round holes - then i change the hole from round to semi-circular shaped. It may not necessarily mean that the dimension between them has changed, but yet they show up in dangling colors (which is understandable) - how do I avoid to redimension?
Instead of manually placing the dimension in the drawing view, use the Insert > Model Items to place them from the model itself, then if the model changes the dimensions remain intact.
So does this mean that there is no way to undangle a dimension without deleting it?
FYI, you don't have to have all the dimensions inserted into a drawing view at once. You can select feature by feature, view by view if needed.
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
