dummy or spacer tubes use?
I am repairing a tube leak and ended up having some of the dummy or spacer tubes removed in our reheat section. I was woundering why are they there is it to support the bundle or to reduce convection. Any help would be of benifit.
RE: dummy or spacer tubes use?
Also, if there is found to be a lot of steam in the fluegas after you restart, it probably was not a dummy tube that you removed.
rjoaks
