variable section sweeps in pro-e
If anyone can help with this problem it would be great.  I need to do a variable section sweep in pro-e.  I have only one cross-section,a rectangle, however I need to vary the cross-section non-linear in both directions.  I have been trying to use the variable section sweep in wf2 to no avail.  I created datum curves to bound the cross-section using table data, and have defined the cross-section as seperate sketches.
I tried to use some of the other multitude of sweep/blending tools pro-e offers but cnnot seem to get this operation to work.  Any help would be much appreciated.
RE: variable section sweeps in pro-e
Here is a couple of websites.  I don't use WF2 so I'm not sure if the menu picks are the same as 2001.
http://www.proecentral.com/portal/articles/articlesDetail.asp?id=25
http://www.ptc.com/go/wildfire/learn/advanced_geometry/index2.htm
http://www.synthx.com/tom/sy_tip_9811.htm
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Thanks for the info.  Its quitting time for me today so I'll try those in the morning.  I appreciate the reply.
Alphaguru,
You should define your cross section from within the Variable Sweep comand after you select your curves and click the correct boxes to choose which trajectory will be the normal trajectory and x-direction for the feature.
If you do this you can sketch your section using the define option to create an internal section sketch SD00## just like you'd do to perform an extrude with out selecting a pre-defined sketch. you should not need to select any references because the sweep trajectories will be points that you can use to tie your section to with sketch constraints.
When I do want to reference other geometry I'll use the X sec refs button in the sketch References window to intersect surfaces or edges with the section plane at all all points along the sweep.
Section referenced to trajectories
Feature Preview showing trajectories
hope this helps
Michael
