Gas Chromatograph sample gas automation
Hello, I'm looking for a more efficient method to feed sample gas into our GC. Currently we capture gas using a vaccum tube which pulls gas into a bag, and then forced into the GC. I want shorten this procedure by a method that transports the gas directly from the collection point to the GC. If anyone has any ideas for any methods or products to accomplish this, I would appreciate a step in the right direction, thanks.
Andrew
Andrew
RE: Gas Chromatograph sample gas automation
Consider a compressor located at the sample probe to "pump" the gas to the chromatograph. An example company is ADI.
htt
A continuous process chromatograph can accept the flow from the compressor. Do not pressurize too high or the volume of gas becomes excessive.
Hope that helps.
It is not cheap. You may need to build a analyser building right beside the slip stream point, complete with power, HVAC, humidity control, etc.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
