Fortran 90: Tab characters?
I have small Fortran 90 question (compaq visual fortran).
I want to write a matrix in an output file, and separate each element of the matrix by a "tab-character". I have found the control edit descriptors to make a tab character in fortran output (e.g. TR1, TL1 or T1), but when I run my code Fortran always seems to write a space instead! This makes it difficult to directly open my text file in excel.
Is it possible to write Tab characters between elements of a matrix please in Fortran? I have included an example of my code below.
Thanks a lot!
Karel
Example:
write(910, fmt = '(3(es12.6e2,TR1))', advance = 'yes') 1.0d0, 2.0d0, 3.0d0
RE: Fortran 90: Tab characters?
The "TL" and "TR" format specifiers just change the position in the current line where the next part of the output will go; they don't result in insertion of tab characters.
Doing what you want is fairly easy. Basically, you want to write a character that has the value of the tab, which is 09. One way is to define a character variable of length one and initialize it to CHAR(9); then just include that variable in the I/O list, with an A format spec to go with it. You could imbed the character in a literal in the format string, but the appearance on screen with your editor may look strange and be hard to work with.
If you're going to import into Excel, it would be better to use comma separated.
If you really want tabs, use char(9)
