screwed connections
screwed connections
screwed connections
Does any body know what the maximum rating is for screwed connections with a tapered thread?  I have a pressure vessel rated at 900bar (1300 PSI) with 80mm wall thickness, 490 (70KSI) grade steel, with a ¾ inch NPT screwed connection.  Is this likely to be OK?   The vessel operates at room temperature.
Many Thanks
RE: screwed connections
What you need is API Circular PS-1533.
email me at kbaxter@diwmsi.com- I have the document in tiff format.
