Assembly Snap Problems
Can anyone shed some light on the use of the "Component Snap" Feature in release 2001?
RE: Assembly Snap Problems
The second is in the component placement dialog box. Select preferences then expand snap if it is not already expanded. There is an option, activate snapping, check this box.
To use it upon component placement the part will need to be in the assembly window while you are constraining it. Select a mate, align etc.. either on the part or the assembly then use Ctrl & Alt to move your component. As you move it various possible references are shown. When you are happy with one release Ctrl & Alt then your part will be constrained. This takes a bit of getting used to.
If you can't understand this or need more help let me know.
Good Luck
Thanks for the reply.
I tried the assembly procedure as you described-no go.
I strongly suspect that it has something to do with the build we are using-2001,320.
We are installing the latest build in a day or so-I will give it another shot.
What do you think about this feature? PTC touts the Assembly Snap as a really good feature.
Thanks again for the reply,
JW
Tactex Controls Inc.
Currently I am using 2001 build 360, however I have been using earlier builds with no problem.
Could you tell me exactly what you are doing, as it can't be far wrong.
I have found this feature very useful and quicker especially when aligning axis.
It seems that I've finally got it.
I did not have "Automatic" selected in the component dialogue box. The automatic snap works well, very much how you described it. Thanks for the config. parameters, it is important to know how to change the snap tolerances.
Thanks again for your help.
JW
