Air Coolers - "Transition Plenum chamber" -
Hello -
Can someone please explain to me what a "Transition Plenum chamber" is and any differences between a standard plenum and the transition one.
Also any advantages of one over the other design?
Thanks in advance,
Kim
RE: Air Coolers - "Transition Plenum chamber" -
Kimdelfield,
A transition plenum in an air-cooler is simply one which attempts to make a smooth change in shape from the rectangular tube bundle face to the round fan ring(s).  I don't think there is any real advantage to this type of construction, but they look nice.  They are certainly more difficult to fabricate than a simple rectangular plenum with round fan rings in the top or bottom.
They have often been used be certain manufacturers, mostly in induced-draft coolers.
Speco (www.stoneprocess.com)
