Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just to let you know...what a great site you have. I posted a pretty generic question yesterday and have had 8 responses already, anyway thanks again and keep up the good work..."
Geography
Helpful Member!  Kisic7 (Mechanical)
10 Jul 06 16:52
Does anybody know how to calculate the CFM on a compressed air leak when the air is not blowing into the atmosphere but into a liquid like the pickling acid?
I am trying to replace a compressed air bubble-system agitator with an energy efficient eductor in a tank mixing application.  However, I do not know how to estimate the amount of air that is currently being blown through the agitator.  I know that the agitator is currently blowing compressed air from a 1/8” pipe, and the CA line pressure is 95 psig.  I do not know the density or the temperature of the acid being mixed but I can easily get that information if I find some use for it.  Is there an equation for CA leaks that deals with the situation of leaks underwater or other liquids?
Please help
Helpful Member!  StoneCold (Chemical)
19 Jul 06 17:25
My take on it would be to just adjust the pressure drop across the hole/holes by the hydraulic pressure of the solution.  So maybe a couple of psi if it is not deep.  Or I would ignore it as it is not going to affect your answer much anyway.  You are probably choked in the 1/8" pipe.
StoneCold
TD2K (Chemical)
27 Jul 06 17:23
I'd ignore it unless it's a really tall tank winky smile
If the air pressure is 95 psig inside the line and it's discharging to the static head inside a tank, you are almost certainly have choked flow through the orifice (dP/Pinlet > 0.5 where Pinlet is the absolute pressure).  If you do have choked flow, the static head in the tank is not going to affect the flow rate.
Close Box
Join Eng-Tips® Today!
Join Us             Close
