Fillet Weld Thickness - how to determine
I’m searching for information on determining or calculating the required “thickness” of weld deposit. Example; I’m welding a padeye (1” thick, mild CS) to a similar metal Plate of 1” thickness, also with ½” thick mild CS gussets, for an oil field application to suspend 10,000lbs of static load from (padeye w/ shackle, 180ft of 3/4" wire rope attached, with 7,000lb load at end of wire rope).
thanks for the input.
RE: Fillet Weld Thickness - how to determine
Based on that, a 1/4 inch fillet weld one inch long is good for a little less than 4000 pounds of load.
There are some additional considerations to make sure you don't overload the base metal that you are attaching to. Your best bet is to take a look at the AISC Steel Construction Manual for the other details.
Good luck.
Design Handbook for Calculating
Fillet Weld Sizes
28 pages, 8" x 10", (1997).
Order Code: AWS FWSH
http://www.welding-advisers.com/
