mechanical advantage-screw thread
I am replacing a manual clamping procedure with a hydraulic cylinder. I am working on sizing a cylinder and system pressure. Currently we use a 1"-8 screw with a 15" wrench. I estimate the we apply about 100lbs of force on the wrench to tighten. I need to know the down force to pick a cylinder. I have plugged the numbers into the formula on pg 150 of the machinery handbook. but am unsure of the units. The numbers seemed quite high from my experience. I am a toolmaker/business owner. I just signed up today this looks like a great idea!
RE: mechanical advantage-screw thread
I assummed a coefficient of friction of .15 to be on the safe side. I would recommend you use a hydraulic cylinder for this application. Without knowing the stroke required or the speed you need to bend your tubing at I can't recommend a specific size. If you send me your e-mail address and what kind of software you have, I can send you the calculations.
Don Leffingwell PE
dleffingwell@snet.net
