Solution to loose coiled spring with force applied radial from inside
I need to find a solution to a loosely coiled spring with a force applied from the inside radial outward. Any suggestions?
RE: Solution to loose coiled spring with force applied radial from inside
Is this for spring clutch?
http://israelkk.googlepages.com/home
The spring is loaded by putting a cylinder inside the diameter. I want to predict the force (normal force/unit length of spring) the spring will produce on the cylinder based on the unloaded diameter of the spring and the loaded diameter of the spring.
No this is not for a spring clutch.
From this pressure and the coefficient of friction you can calculate the friction force. However, since not all coils will slip together you may have a very erratic behavior because you also stretch a spring with variable coil numbers resulting with variable spring constant and deflection per unit force.
Mechanical Analysis and Design
