Need 10" Steel pipe cap
Anyone know where I can find a 10" steel pipe cap similar to this? (second from bottom)
http://www.mcmaster.com/nav/enter.asp?pagenum=3546
I need to cover a 10" above ground drain (hub) and this seems to be the easiest alternative
RE: Need 10" Steel pipe cap
http://www.m-p.com/metalpipeprotectors.htm
http:/
Took a while, but googling "metal pipe cap" did the trick.
