Applied Statistics - Predictive Maintenance Data
I want to expand my working knowledge of statistics in regards to analyzing predictive maintenance (PdM) data, such as vibration or oil analysis results. I'm familiar with the basics of setting alarms at +/- multiples of standard deviations, but I would like to learn more about statistics in the hope that additional information can be pulled from the collected data.
Can you recommend any textbooks, short-courses, websites, distance education courses, etc. that provide practical examples to real data?
Thanks!
Steve
Thanks!
Steve
RE: Applied Statistics - Predictive Maintenance Data
If you want look for additional information within your data, where the abscisa is time, then I would suggest you to start exploring "time series". However it is more complex and from programming view point much harder. One of the many times cited sources is the "Time series analysis, forecasting and control" by G.E.P.Box and G.M. Jenkins.
If you go deeper into frequency domain you should turn towards spectral analysis. A "Spectral analisys and its application" by G.W.Jenkins and D.G.Watts might be a possible starting point.
This is my choice and someone else would advice you different sources of course. If you want more detailed information about particular editions or more sources I can give you an extended list.
m777182
With this you can perform the whole host of relationships and statistical modelling, that is virtually impossible with excel. We use this for the six sigma improvement projects we run and Minitab is definitley our best friend when it comes to statistics, as all the calculation is done for you and the graphs are excellent.
You would need some basic statistically training through Minitab or Six Sigma to be able to use and appreciate the power of the software.
http://www.statsoft.com/textbook/stathome.html
Great (FREE) reading,
HIH, dog
