Failure criteria?
Failure criteria?
Hi, what is the diference whether we set up fail stress, (fail strian) or not?
When I plot data from field output, I didn't see the differrence?
RE: Failure criteria?
http://www
i am working with DEBOND two surfaces, my file get this kind of massage: "THE SLAVE-MASTER PAIR ASSEMBLY_DB2 ASSEMBLY_DB1 SPECIFIED ON *DEBOND HAS NOT BEEN DEFINED. THIS MAY BE DUE TO NONEXISTENT SLAVE OR MASTER SURFACE, OR DUE TO ERRORS WHEN PROCESSING THE *CONTACT PAIR KEYWORD". Althought i have already defined it in CONTACT PAIR and again in INITIAL CONDITIONS. Please help me how to solve this problem.
Phanhung
i get this error:"TOO MANY ATTEMPTS MADE FOR THIS INCREMENT". Which parameters will be consider to deal with this case.
And when i using FRACTURE CRITERION, TYPE=CRACK LENGTH. ABAQUS have already give me a result, but between two surfaces debonding were not seperated. Please tell me the reason.
Phanhung
