Adding configurations to design tables
I am wanting to add an existing configuration to a design table. (It existed in the DT before, but was deleted). When I edit the DT, I am no longer prompted to include this configuration.
The only way to have taht dialog box show up is to save, close, reopend the file, then edit the DT. Then I'm prompted to include the configuration in the DT.
Any way to quickly add the configuration?
John Graham
Mechanical Design Engineer CSWP
John Graham
RE: Adding configurations to design tables
When I type in the new configuration, as you suggested, and close the DT, the DT thinks all the custom properties don't have values. When looking at the custom properties through "file: properties" menu, they are all gone.
John Graham
The DT should populate itself with existing properties & the differences between configs.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
