Non linear analysis of thin plate structures
Is anyone familiar with structural software that can do non linear analysis of thin plate structures?
RE: Non linear analysis of thin plate structures
You might check in the Finite Element Analysis forum.
will NL codes handle buckling of skins under shear and compression loads (diagonal tension ?)
