Applying Displacement Constraint
I'm having difficulty in defining a displacement/velocity constraint on a part. I want this particular part to be stationary from time = 0 to time =.005 seconds; then, the part would rotate and move axially based on a certain spring force. Can anyone please give me suggestions?
RE: Applying Displacement Constraint
Cheers
Greg Locock
Thanks for your valuable advice. I don't know how to deactivate a fixed joint after a certain time interval. If you could give me more details on this, that will be very much appreciated.
-Agdyp
Cheers
Greg Locock
