Hvac For Laundry Room
I'm the doing the Hvac design for a 200 square ft. laundry room. It has 6 washers and 6 dryers. The room is to be cooled and heated. The dryers will be exhausting 150-200 cfm each. I plan on sizing the exhaust header so I don't have to use a fan. Would an outside door louver be the best way to introduce the outside air or would I need to use a dedicated make-up air unit? If so, wouldn't I need to be able to throttle the make-up air back when only a couple of the dryers are running?
RE: Hvac For Laundry Room
Dave
