V4 face to solid ??
V4 face to solid ??
In V4 I have multiple faces that make up a sheet metal profile. How can I create a solid defined by the faces? I want to create tooling in order to stamp this particular shape into the sheet steel.
RE: V4 face to solid ??
Good information, I tried using the split command however I get "Too short surface" error message. I varied the size of the solid relative to the skin and I continue to get the same message. Any thoughts?
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Try using the solide > complex > project.
Select the skin and then a plane that would represent the back side of the steel.
