Remove folder from Toolbox
I created a new folder using the Add My Parts Wizard. I would like to remove it. I deleted the tables in the database and now I get and error when I try to access the wizard saying that "Microsoft jet database engine cannot find input table or query _____. Make sure it exists and that its name is spelled correctly".
Is there a way to just delete the folder or do I have to go into the database and recreate the table? Could I just copy another table and rename it?
Thanks.
RE: Remove folder from Toolbox
You should never access the DB. When you do SW will not support any changes made to that file. You wil have to get a copy from someone else, or reinstall TB.
To not see the newly added folder you need to go to:
1) Tools\options\Data Options
2) Expand the folder if it's located in an existing folder, otherwise just click on the main folder that you add through "add my parts wizard".
3) Select disabled in the menu to the right and click OK.
4) There is a known bug that will cause SW to crash here, but it should still accept the "disabled" option and next time you start SW that folder will not be seen anymore.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
