rotating bends
rotating bends
How do I calculate the distance in the x, y, z planes if I wanted to rotate, say, a 10-foot segment of pipe attached to a 22.5-deg bend by 45 degrees? That is, how do I illustrate the difference in station and elevations depending on how much I rotate a x-deg bend?
RE: rotating bends
http://www.acipco.com/adip/products/Sect17.pdf
