Save file without version number
Hi to everyone ...
I'm Pro/E superuser and for a special application I need to save (Menu>File>Save) files without version number.
In other words, I'd like to save always overwriting the same file. (filename.prt - without .#)
Coud you helm me?
Massimo Piva (Italy)
RE: Save file without version number
I'm not aware of a way to tell ProE to overwrite.  You may be able to create a custom 'Save' button that shells out and deletes the file before the real save.  That way ProE will always create a .1 version.  If you decide to try this, I recommend 'renaming' the file instead of 'deleting', just to make sure it's doing what you want.
This sounds like a scary thing to desire.
<tg>
You might be able to write a mapkey that deletes (or as telecomguy suggested, renames) the old versions before saving the new one.  Just use the OS script tab when writing a mapkey.
P.S. Nice World Cup Victory over Germany!
Massimo,
Go to the following link and download the spurge program. You can configure it to remove the numbering system used by ProE.
http://spekantools.innotiv.nl/
-Hora
Found another link to this great tool:
ftp://proe:*****@celkunststoffen.khlim.be/stud/Spurge_2.4.exe
-Hora
