Teck cable under -40C
I need run 3#12+GND Teck cale in an environment with -40c. are there any special requirement for this?
Thanks in advance.
Thanks in advance.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Teck cable under -40C
Once installed there is no further problems as long as vibration is avoided and there is no movement of the cable when it is cold. In cases where a flexible connection is required, Teck may be run to a junction box and a type of cable suitable for movement in cold environments used in the area where flexibility is required.
yours
