303 vs 304
303 vs 304
I am making some prototype parts for use in an aircraft wing actuator. We typically use 304SS. I have 303SS on hand and can get the parts faster if I use it. The components are small, less than 1 inch diameter, and basically house some bearings and other components. Not a lot of stress. Does it sound like the 303SS would be an acceptable substitute? Thanks in advance.
RE: 303 vs 304
RE: 303 vs 304
If you want flight hardware, no way.
Some 303 isn't too bad, but some of it is awfull.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: 303 vs 304
