sprinkler pipe outside
I may have been around to long. I thought NFPA 13 use to require fire sprinkler pipe located outside to be either galvanized or painted. Cannot find it in the 2002 edition.
Any help??
Any help??
RE: sprinkler pipe outside
8.15.3.2 Protection of Piping Against Corrosion.
8.15.3.2.1* Where corrosive conditions are known to exist due to moisture or fumes from corrosive chemicals or both, special types of fittings, pipes, and hangers that resist corrosion shall be used, or a protective coating shall be applied to all unprotected exposed surfaces of the sprinkler system.
It is the conditions due to moisture that gets a lot of people. Some will claim that relative humidity will be an issue and require galvanizing for exterior piping. Others will say that if there is a covering so it does not get directly rained on that you don't need galvanizing.
Good luck
Thank you all for the replies I thought it use to be there. I still would question pipe on the outside not requireing to be protected. Even in so called normal condtions I have seen outsdie pipe that does not look good.
It's amazing what high humidity salt air can do for unprotected sprinkler pipe in Florida.
This should remain a locality issue.
