discharge coefecient of fire sprinklers
What is the discharge (K) coefecient to be used on the typical fire sprinklers. The simulation will be carried out for metric units.
rgds
rgds
RE: discharge coefecient of fire sprinklers
typical k-factors for commerial heads
orifice US (metric)
1/2"..........k=5.6 (80)
17/32"........k=8.0 (115)
7/16".........k=4.2 (60)
3/8"..........k=2.8 (40)
10mm..........k=4.2 (60)
15mm..........k=5.6 (80)
20mm..........k=8.0 (115)
there are many makers and styles of sprinklers you should find some catalogs (on line) and they will be most helpful. some design specific heads require a minimum flow from the sprinker.
flow = (k)(square root of pressure)
just what is it you are trying to do?
hope this helps
G3
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
There are many other variables that come into play when selecting the K-Factor for sprinklers.
OK, I'll bite: What is the purpose of the simulation?
